- Jun 8, 2017
- 255
- 0
- 0
Does anyone know if when you are using split screens and more than one has audio, is there a way to mute or select which one is playing the audio?
Never used it that wayI think the op means if you open two apps on the inner screen thus using split screen and both are playing different audio can you choose which one to listen to.
Guess everyone has there wayTo be honest I've not used split screen that way either too !
