Fold 6 Cases!
I got the spen case. I liked that they didn't use tape so you can take the back off if needed. Looks like some are reporting it pops off easy, I haven't used in real world yet to find out.
A big downfall, it doesn't allow wireless charging. What did Samsung change, my fold 5 wireless charges with spen case.
Oh yeah, it's thin enough. If you want the one I got I can link it for you.
I had searched it from your post. I had tried it last week, and found the corners lifting and gave up. I use the pen a lot, and really wanted this case to work out, so last night I did what I should had done last week. I removed all the adhesive including the black strips Samsung used so it was bare plastic. I placed the double sided tape in those spots and tried it again, so far everything is perfectly flush. Placing it over the existing adhesive made it slightly too tight. Thanks for the suggestion! Now if they would only release this case in black.
Reactions: TMavC5
The Samsung Spen case does pop off easy the front cover that's why I went with different brand with slim Spen Holder and built in screen protector and love it
Reactions: TMavC5
Can you use Samsung Spen with your case? Also, please share the link.
This is what it looks like
Can you use the SPEN that came with Samsung case with other case you're talking about? What's the case link?
It comes with its own Spen but didn't like it , so yes the Fold Spen fits it and what's in it now from the picture
Reactions: TMavC5
Yeah, I noticed it's not an SPen but just a pen with a soft pointer.
My two-sided adhesive works well with the SAMMY case and stays on very well. It only moved around because I don't have any screen protector on it yet. :(
Reactions: mustang7757
I've tried the Samsung case and the front doesn't stay after time I believe through the fold 4 and Fold 5
This comes with front case screen protector and no bubbles, works flawless
Reactions: TMavC5
Just ordered the Z Fold6, going from my S24 Ultra so I'm not familiar with cases for the Fold at all. I want something that is completely clear and completely minimal, don't want any added bulk. Also will need a fingerprint friendly front screen cover that is also case friendly.
TIA for any suggestions.
Beboomo
