Font color change?
A whole lot of "This is what mine looks like..." but yet, not a single explanation (otherwise known as "an actual answer to the forum thread OP") as to how it was accomplished... wow! Absolutely infuriating on so many levels. As soon as I find the actual answer, I'll return with it. :-/
It is possible for rooted users However if youre not rooted You're juat stuck with plain old wite
With my Samsung, I went into my Settings, then Accessibility, then Vision, then chose High Contrast Font. It helped by outlining the icon font in black. It didn't change the color, but definitely made the font more readable on a lighter background. Doing this will, however, change all fonts on your device, not just icons font.
I hope this helps!
Go to the settings cog of your Samsung Galaxy and on the Search Bar. Type Auto Reverse text colour. Under Transparency slide from Low to High so you can see the text getting darker
yanis
