- Sep 22, 2014
- 2
- 0
- 0
Dear experts,friends,nerds,
It happened on a stressful day.
I wanted to remove simcard from my Nexus 7 LTE(2013) and pierced a pin into the hole on the side withouth any doubt and noticed it goes too deep. What happened is... I pierced the pin not into Simcard holder but into Microphone. And It damaged sure microphone and battery as well.
After this, it went warmer than before where the batter is and it turned off. In 5 min, temperature turned normal. I opened the cover and took a photo.
I cannot turn on anymore and put charger in but nothing happen. When I keep pressing power button, white LED on bottom blinks 5 times and after some pause 5 times.
So Would you give me some advice ,how I fix this problem? What can I try? I bought this from my friend. I should fix this by myself or repair shop.
Thanks advance for your help.
