So for the last week or so, i've noticed that when I unplug my phone from overnight charging, its no where near fully charged. After about 6-7 hours plugged in, it would only be at about 70%-80%. I found it a bit curious and finally had a chance to do some troubleshooting last night.
I already have a battery widget installed, so I used it to let me know what is going on.
I plugged my phone in at bedtime around 11:30 am, the phone was at 19%, and the widget stated that I was connected to AC power charging. When I woke up this morning around 7am, the phone was only at 60% and stated USB Charging. Ah Ha! Found the issue.
Now, i'm not sure why it went from AC to USB charging (I checked both ends to make sure the usb cable was secure) but i'm hoping that it is just a faulty adapter and google will replace it. I have another adapter that I am using now and I will see if I get the same results or not. This should clarify where the issue is.
Hope this helps anyone with apparent slow or no charge issues. I know i've seen many threads regarding similar issues, but have dismissed them as "Eh, they are probably not using the stock charger". I stand corrected now!
I took a quick screenshot of the widget I use for reference.
