? For those with Seidio suface case
79berry
6
New to the forum here and recently got a note 2. Was looking to get the covert case which uses the suface as the first layer. I was just wondering if the slide on installation of the case would scratch the screen of the phone? I know on some of the harder plastic and metal slide on cases on certian phones would scratch as the case was slid off and on. Thanks for the help. Also if anyone knows. Would the covert case work well with a mime ghost sp? Already have the mime on order. Thanks again
Yes it can, all you need to do is be in a dusty environment. Mine has light scratches on the sides from dust getting inside the case and me sliding it off to clean it with a moist towelette.
Sent from my Galaxy Note II using Android Central Forums
I scratched a RAZR Maxx with one so yes it can.
Sent from my Samsung Galaxy Note II
it has not scratched mine (at least yet) and its been on and off many times, but i work in a data center, so not too much dust there!
Thanks for the feedback. Got the convert case in and it seems like it's going to work well. Just waiting for my mime sp to come in sometime next week. Then I'll be able to switch out from the defender case.
mostafamu
