Former Skyrocket users, battery question please.
dalvik
1,131
62
any former Skyrocket users here that could provide any feedback on the SGS3 battery size and if it can fit inside and work with the SR? I'm thinking of the possibility of using the GS3 battery on my Skyrocket and I know people use Galaxy Nexus battery with SR and it works just fine
your feedback would be highly appreciated. thank you!
No they wont work together. The skyrocket battery is shorter and slightly wider so it won't fit the s3. That was one of the first things I checked.
Reactions: dalvik
Thank you VERY much for your reply. I couldn't find this answer anywhere. Greatly appreciate. Thanks again
riyajhox
