Found a fix for One S audio jack problems.
Mollie Tillman
3
OK, SO IF YOU ARE HAVING ISSUE WITH YOUR MEDIA, PHONE NOTIFICATION SOUND, RINGTONE NOT GOING OFF, VIDEO NOT WORKING,OR ANYTHING SOUND RELATED, LOOK NO FURTHER!!!
[I know you have to pay for this app to access all of it, but it was so worth it, saved my phone, and was only a one time payment.Hell, if u won't, I seriously will for you just to get karmic payback. I get free google money anyways. (that's through google opinion.google gives u money for surveys.) the app is sound about. Make sure you have make a desktop item on, then hard select your home screen. It will show what widgetsyou can put, select it from the menu. Ill put it in a comment. Its called audio jack reset
Basicallywhat's wrong is our phones headset jacks are screwed up,so you needed top be able to manually shut the jack off occasionally. This is the only hard and true fix.I've been through all the forums to try to fix my own.it's legitimate. i Would like to point out I'm not being paid by the guy who made sound about to advertise, or market it. I don't know him but if I did, he would definitely get a hell of a lot more than a thank you kiss from me hahaha.saved my life with that app it seems
Ta, Mollie
Good day .. pls am also having the same problem with mine ,pls someone should hep me out .. pls my number is +2347081743326 .. pls help me out
First off, don't put your number. Secondly, that fix should fix your sound. Sound about. It's not hard to navigate. When you click on my name it takes you to my Google + page I think. Go ahead and see details there
I have the same problem. My sound doesnt work. Resetting my phone seems to fix the problem temporarily. I bought the app. Can you give me a step by step of what i should do. Please and thank you.
Hi. I'm Jenny. I need serious help. Same issue and I don't see the app up on the play store. Is it gone? This was my last hope.
I looked up audio jack reset
Solution: Get an HTC ONE M8
Adriana305
