framework question...
Changing the .9png's were easy. The hardest one to find was the phone_accumulator_bg.9 (which is the top border).... That one was just a tad tricky to work on because it's a stretchable but the actual image is really small (big reason why it was hard to track down too). But checking it with the draw9patch in the sdk tools makes it almost idiot proof to edit wrong. If I remember correctly the bottom one was the common_main_panel_navbar.9. The background was phone_keypad_background. To get the dialer pins black, i just had to edit the htc_pin_asset_rest.png. To get the "glow" effect was real easy. Just optn the htc_pin_asset_pressed.png and erase the entire image. Then pick one of the fade style brushes in photoshop and start from the outside, and work your way in making it darker as you go in. Then you have to edit the htc_pin_icon_pound, htc_pin_icon_record, and the htc_icon_record images to white. This is when it got tricky. I found out after some searching (and editing damn near every dialer pin image for nothing) that the font color and layout is controlled in an xml file. Vaelek (the developer of the VaelPak roms) spent a lot of time with me explaining XML and teaching me the basics of editing them. We both spent a WHILE searching for the XML that controlled the font color and Vaelek eventually found it. It was a styles xml. I had found that themed dialer a little bit before he found the XML. I was trying to get the exact same look of the black/white numbers/letters even before I found that theme. I was able to pull that off on my own but I also liked the layout of it. That's the roadblock I hit. I couldn't find where the xml's were located that controlled the layout. Vaelek suspected that there may have been some smali edits which I know nothing about. I know nothing about smali or how to edit them. So after reading that JsChiSurf made code changes, we both suspected that those code edits were in smalis. So I took the smalis, and a two xmls that were different than mine and dropped that into my apk. The only thing I didn't edit was the layout (I already had the font). I thought I had given credit for the layout in my post but obviously I didn't, but will after I'm done with this post. So ya, everything was done by me (huge thanks to Vaelek for spending literally hours with me teaching me and helping me with it) except the layout of the numbers/letters.
Ok bringing this back from the dead.... So as a couple of you know I had a complete failure of all my USB's a few weeks ago. My "theming" basically went to a standstill. Thankfully I had a backup computer (that's actually identical as my other one). Windows had crashed on it so all I had to do was throw Ubuntu on it and I'm up and running again. It's taken some getting used to but yet again huge thanks to Vaelek for the insane amount of help he's given me. So now that I'm up and running again I wanna get back on this theming. Problem is I have NO idea how to resign an APK after I'm done. I LOVED the resign tool from the themes sticky where all I had to do is right click and select resign.. Is there something like that for Ubuntu? Is there at least a simple command I can do? Or what are the other options. Also, I of course forgot all the damn adb pull commands. I really don't want to swap all the wires to the other computer and have to write them all down. Could someone tell me what are the adb pull commands again for at least the comhtcresources and the res framework. i think that's all i need to do the bulk of the theming. Thanks guys.
Well.. made some really good progress last night. So far I've edited well over 300 images (150 for the battery icons alone O_O). I'm still not done, but last night I definitely made some big progress. I took a look at the framework-res from Myns and compared it to mine to see what images were changed in Myn's so it could give me an idea of where to look at and figure out what those images are for. I got tired of playing manhunt with images... It helped a LOT. I spent about 8 hours last night editing images and I'm really happy with what I came up with so far. A good part of that time was spent reediting some images I had edited earlier because I just didn't like the look anymore. I did spent way too much time editing .9 images. I can't say this enough.. it SUCKS. It's SOO annoying to spend time editing a .9 image, having to repackage the apk, resign it, go to recovery and push it, reboot, only to see it be a complete disaster or worse the phone wont go past the boot animation. After about 3 hours trying to edit my own popup images (a total of 4 images) I decided to just take those from Myns. I'll get back to them another time and do what I really wanted to do with them but I just don't have the damn patience right now. But for honesty and transparency I will admit, I used a total of 4 images from Myn's (tho temporary) lol... popup_bottom_dark.9.png - popup_bottom_medium.8.png - popup_full_dark.9.png - popup_top_dark.9.png..
All other images were edited by me..
ditched that brownish tint thing i had. Wasn't feeling it anymore. I think a nice dark tint looks much cleaner..Gives it like a tinted glass look or something.
I still have to edit the little green guy..
