freezes when switch to max battery saver
danb72
Hello All - so when I try to switch to max battery saver mode, it goes through all the steps in the process indicating its done, except it never gets past the last one. the status indicator keeps going round and round, and i cant even exit the screen by pushing other buttons, i have to restart using power key and vol down button. lately ive gone through phone and have tried to turn off and disable and uninstalled some updates on bunch of stuff/apps it looks like i dont need or use. but i do that all the time and it hasnt done this before. Any help appreciated...thank you
just did this and didnt help..........
turn phone off
Hold volume up + power + home buttons
It will say installing update then do some android hanging by a noose image and freeze for about a minute don't worry it will take you into another screen
Use volume down button to go to wipe cache partition and press power key to select it the choose yes
theantithesis
