- Jan 9, 2011
- 122
- 6
- 0
Thought this might help for those having battery life issues. I haven't really found the battery life on the Shift to be all that bad myself. However, I did notice a big difference from yesterday and today. My usage doesn't vary much from day to day. But most days when I get home from work I am down to around 40% on the battery. Last night I removed the Friend Stream widget as it seemed redundant since the only social network I use is Facebook and I prefer the Facebook For HTC Sense app. Went to work today, used the phone like normal (I was even in more roaming areas today than normal) and when I got home from work I was still at 68% battery life left! Removing Friend Stream was the only change I made to the phone. My guess is Friend Stream eats a lot of power even when you have it set to sync only every two hours like I did. Hope this helps!
