Froyo help: weather and sense?
RealFnCool
70
5
im using 2.2 and im having an issue with the weather htc wigdget... even the app itself.. doesnt have the "current city" option.... how to i activate this?
also, how do you turn sense off on 2.2? old force stop method doesnt work anymore.
thanks!!
Disabling Sense hasn't worked since the 2nd OTA update.
You can download an alternative that will work...LauncherPro is probably the best one.
Well on mine, when I make a new widget with either the HTC Weather, or HTC Clock, I have the option while creating it for "current location". The app itself, I'm not sure about, there's a plus button to add cities, and on mine it automatically has current location as the fist city.
scoobyd031883
