G2 D802 reboots when sync enabled
This exact issue happened to me yesterday, except mine is a Galaxy S4, my only temporary solution was to turn off sync too
Hi, I think now it works without syncing continuously. I uninstalled Play Services and deleted Google Account. Reboot device and reconfigured Google account and upgraded Play Services. After 1 day I could say it seems to works now.
I that fixes it , good spot again with that google services framework. clearing, my phone was loony crazy on reboot loop cycle
I'm haven't right to delete play services, my telephone is not rooted
Thanks to the folks here My Moto X is back up and running without needing the dreaded Factory Reset. :)
My initial attempt (uninstall play services update, Reboot, and then re-updated Play Services) stuck me in the constant sync scenario, so I repeated exactly what webfrank stated above and this time it worked successfully. I guess removing the google account is important.
Thanks again to all
is not about root, my phone is not rooted also, you just click on the device administrator field and you uncheck the android manager or how its called (the green option), than you are allowed to uninstall the updates, you don't need to delete the application just remove the updates
maryhurst515
