G2 Music Player Problem
Kendall Williams
Hello all, I did a search and did not come up with anything. My problem is that when I am adding music to the phone, sometimes it will put artists out of order. For the most part it is in alphabetical order, but some artists go at the top of the artist list (above "A"), even if they are an "I" or "D". I am using "Android File Transfer" on a Macbook Pro. Please help, any advice is much appreciated! Also, if there is any other Mac to G2 program that is better, please advise me; this program has no options to search or edit the music.
Not sure if this is the case but do you have a space as the first character in the ones that are out of sequence ?
No, great suggestion thought! I checked and there is no spaces....I got excited that it was a quick fix too lol. Thanks, I appreciate the suggestion.
I may have a solution to your music management problem with the LG G2. (and I am new to forums, so I may be doing this wrong)
I just got my LG G2 yesterday, but I found the same problem you did. I came up with a solution (That worked!)
First, you'll need to take the music off your device and put it on a computer.
You'll next want to go into the properties of the file (You can highlight all the files at once!) and look in the section labeled "Comments." This spot needs to be EMPTY in order to organize properly! Hope that helps!
Babby bobby billy
