G3 camera problem
utkarshc
Hello all, I have a problem with the camera. For the first 2-3 minutes afte switching on the camera shows some red and blue lines like a noise signal in video. It also comes when I take the picture. It only happens for the first 2-3 minutes and then it disappears and picture is clear. Tried using other apps for camera, but the problem still remains. It only happens during low light situation or during night shots. Any suggestions
That sounds like more of a hardware issue to me (based on the symptoms and that other apps have the same issue), but I guess I'd suggest trying a factory reset if you can manage it.
If you are still under warranty you might look into getting it addressed/replaced.
Khalequzzaman
