G7 notification LED
flever
5
If notification setting and LED blink setting etc. are all enabled, do your G7 LED blink when receiving app notifications? Mine only blinks for a few apps but not others. The weird thing is that it doesn't even blink for the built-in email app when email is received.
Welcome to Android Central! My fiancé's G7 does get a notification light for app notifications. Which other apps do not receive notification LED on your end?
Thanks.
It doesn't blink for the built-in email app, McDonald's, Kijiji etc. There may be more I'll find out.
Hi folks, do your G7 blink on the built-in Email app, and other apps? It would be helpful to determine if there is any software/hardware issue. LG support says send in the phone for inspection but I'm not sure if that will be helpful.
Download 'Light Flow'. You can set any app for notifications and multiple colors also.
Thanks for that idea. At the mean time I also wonder if it's hardware issue causing the built-in Email app not blinking, as the support person said. Can you tell if your built-in Email app does or doesn't blink?
My phone did not come with a built in email app. I think VZ removed it from their version.
sportzfyapp
