Galaxy Ace 2 GT-S7560M restore help! (I think I bricked it pretty badly)
anon(7859740)
So I tried to unroot my phone using Odin and a a stock firmware I found that was for Telus, my carrier, and half-way through it said that my Galaxy Ace 2 Gt-7560M had encountered a problem and needed to be recovered in Kies. So I downloaded Kies, and all the drivers and such, but the phone wouldn't connect, it would just be at the connecting screen for over 30 minutes. I can't enter download/recovery mode as it just shows the encountered issue screen every time I turn it on or try to enter download/recovery mode. Anyone know how I can revert it back to normal and unrooted? I'm really stuck here, and I'm worried I bricked it for good...
Hi,
Did you receive an answer? I have the same problem plus my wifi stop working too.
Thanks!
Tank
Hi,
Thanks!
Tank
This was quite a while back, haha. Anyhow, I found resetting my phone with Kies worked, after backing it up, I reset it, worked like a charm!
Mario Zelda
