Galaxy Nexus best case
I'm thinking about checking out the Trident Aegis case, but I need to know if it will work with the extended battery.
Anyone know or have it?
Steve
I just got the Ringke SLIM Standard/Extended Battery Case. A bit pricy, but really a good case. Smooth feel, doesn't pick up lint or stick in your pocket. Cutouts are perfect. Fits with 2100 mah extended battery.
If you're looking for another VERY protective case like the OtterBox Defender then I would go with the Seidio Convert Case. That case makes your phone pretty much invincible and I know there are extended battery options. The thing comes with a locking holster as well!
Reactions: jfriend33
I just received my Rinkge Slim case and it is thee best Slim case I have ever had for a phione. I never thought for a reasonable price you could get a case so thin that did not feel cheap. This thing is tight fitting and has enough space for the stock extended battery. It simply feels like it is still a naked phone no joke.
DO NOT buy the defender if you have an extended battery. Yes it fits perfectly initially but eventually the closure will break and it comes loose. I'm on number 3.
Otterbox was kind enough to ship me a commuter free of charge with extra screen protectors.
Best case is Seidio convert. Slim case, converts to double layer, then even can add another plus belt clip. Get the extended one.
ZackS
