Galaxy Nexus HSPA+ question
not true. my local corp store scanned my imei number from my gnex, gave me a new sim and added me to the unlimted hspa+ data plan. I was presently on unlimted for iphone. I simply added the att us hspa apn
you should see billing code HSDPPB in OLAM
the only reason you see 3g instead of H in the status bar is because the gnex only uses hspa+ when actively pulling data. it took me a second to get the screen shot so it had switch hspa+ off by the time i snapped it. you will only see an H on the gnex not H+
Click to view quoted image
Can you post your APN settings! Those speeds you posted are the best ive seen!
Name: AT&T US HSDPA
APN: phone
Proxy: <not set>
Port: <not set>
Username: <not set>
Password: <not set>
Server: <not set>
MMSC: <not set>
MMS Proxy: <not set>
MMS port : <not set>
MCC : 310
MNC : 410
authentication type : <not set>
APN type : default,supl,agps,fota,dun
Name: AT&T US MMS
APN: wap.cingular
Proxy: wireless.cingular.com
Port: 80
Username: <not set>
Password: <not set>
Server: <not set>
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS port : 80
MCC : 310
MNC : 410
APN type : mms
I am using a iPhone 4S now and waiting for my Galaxy Nexus in the mail (should be here tomorrow can't wait). I will see what the speeds are when I put the sim in from my iPhone. What iPhone did you come from?
Yesterday I could see the 4g icon next to signal strength icon, today I don't. Anyone know why?
Uh, your iPhone 4S SIM wont fit in the Nexus
I have a micro sim card adaptor. It seems to work fine with my Nexus S. Maybe its different in the Galaxy Nexus. Guess I will find out.
agreed. i just gave them my imei # and they input me for the tiered 4g data plan. on a side not, you can confirm an hsdpa+ signal if you go into settings-about-status, and look under mobile data connection, when i'm in hspa+ coverage its either category 9 (san diego) or category 11(missoula, MT) yes i travel often between both areas lol. ...but neways ya, att's latest standard for 3g should only be category 6 or 7 (7.2mbps) and hspa+ is considered cat 9+.
Also, i do notice it only stays in hspa+ mode when actively pulling data and idles in 3g mode, which i think is pretty awesome.
I moved my iphone4 SIM TO my GSM Galaxy Nexus using adapter and it is working perfectly.
I'm pretty sure H means what AT&T claims to be "4G" (aka HSPA+). 3G means the very similar HSPA standard. For some reason N4 says H instead of 4G. Maybe because it's not LTE?
NVK
