Sounds like you are on a GSM carrier. That means you actually have a choice. The SGSII is a nice phone. I wanted one myself.
Nexus has very similar hardware as the RAZR, same processor and RAM. The screen on the RAZR is a lower resolution, but for what I am going to say, that won't matter AFAIK*. CF-bench listed the RAZR as slightly better that the world version of the SGSII. By slightly I mean not enough to notice. So both phones are pretty much equal. The camera spec is a wash IMO. Bigger pictures are not better pictures. You might be able to get clearer pictures with the Nexus, but definitely faster on the Nexus. ICS is amazing IMO. It doesn't need a skin. The UI is what GB should have been when they promised an upgraded UI. The SGSII will get ICS,and it will work better after is does. It may even beat the Nexus.
I am getting a Nexus to have zero bloat. I am on Verizon and they load phones up with crapware. I also want updates as soon as Google updates Android. You need to choose your phone based on what you expect. If you want zero bloat and speedy updates, get a Nexus. If you don't mind bloat, you like touchwiz, and you don't mind waiting for Samsung to modify touchwiz to work with ICS, then get an SGSII.
*Screen resolution from highest to lowest: Nexus>RAZR>SGSII
