Hi guys, I just got this Galaxy Note Olleh (SHV 160K) and I want to get rid of those korean apps But Im just new with this matter. Can someone help me where to begin first? Coz I don't have any idea Thank you in advance! It means a lot!
Welcome to Android Central! Those apps are likely preinstalled bloatware, so you might not be able to remove them unless you root your phone (which I don't recommend for beginners). To see if you can uninstall them, go to the App Manager, select the app, and see if there is an Uninstall button. If so, great. If not, then see if there is a Disable button. Disabling an app prevents it from opening (so it won't take up any of your active system RAM).
