Galaxy note 2 battery questions...
umer yes
6
i got my note 2 yesterday and i used it the whole day with wifi constantly on(browsing), listening to music, with sync off everything is perfect the only that bugs me is the fact that it only lasted 5 to 6 hours.Does your note 2 last the same when using it heavy or is there something wrong with my battery or phone? and one thing more, when i view my battery drain apps, google chrome is usually the 2nd or 3rd on the list, is this normal? honestly i was expecting much more from this phone battery wise....thanks
It depends on what you have running, signal strength, on screen time, settings etc.
I am a heavy user and on stock I could get 5+ hours on screen time with stock battery if I use Wi-Fi. I'm in a weak signal area so on 3G I would get 3-4 hours on screen time.
I don't like to worry about battery life, so I choose to get a 6500 mAh extended battery. Now I get 8-9 hours of on screen time. I'm happy with it and I like the bulk.
Screenshots of your battery stats would help us determine what would help improve your battery life. :)
Sent via Note II
Browsing and listening to music can put a strain on the device. There ways to help you conserve battery life as much as possible by doing a few simple things that are clearly explained in this thread:
http://forums.androidcentral.com/general-help-how/298919-guide-battery-saving-tips.html
If you have questions feel free to aks or post in the above thread.
Remsangpuii
