Galaxy Note 3 - Screenshots/Homescreen Thread
Tried it with Nova running & stock ... didn't work for me :( Thanks for the reply :)
Cheers, Jon
Hold the home button and power button at the same time. Same way to take a screen shot of any other screen. I just tried it and it worked fine for me.
Aviate
Sent from my SM-N9005 using Tapatalk 4
Just tried that & Home-Power doesn't do a screen capture on any window or lockscreen. I had tried that & tried all the others tricks to. All work except Home-Power for all screens & none work for Lockscreen.
Cheers, Jon
Cheers, Jon
Just to be sure, you are holding both buttons for at least a couple of seconds and not the quick iPhone way, correct?
Sent from my VZW Samsung Note 3
Every way possible .... it just goes to sleep on the lock screen after a couple of seconds & on any other screen nothing happens. I press/hold the Home & then immediately press & hold the power button & keep holding both.
Cheers, Jon
Cheers, Jon
No, you don't press them separately.
Take your phone and press BOTH the home and power button at the same time and hold for a second.
Here is mine for the next 12 hours or so lol. I change my home screen quite frequently.
This is using:
UCCW Widget
Nova Launcher
Black and Red icon pack
Heres mine.. like to keep it simple :)
Sent from my SM-N900T using Tapatalk
Here is my current one.
Nova Launcher Prime
Icon Pack - Black and ICS
UCCW Animus Clock
Sent from my Galaxy Note 3
My lockscreen and current home screen for the time being. Dynamic notifications as my lockscreen. Nice prime and nox icons as my launcher. I keep flicking between this and stock touchwiz.
LilPandaBear1105
