Galaxy Note 4 5.1.1 ATT
Silly thing to ask because I'm sure you guys know this, but if you're doing it OAT, is it plugged in?
Or I could just be wrong.
Sent from my gorgeous sexy white BEAST of a Note 4 ❤
Mine updated overnight. Definitely much smoother. After all the apps updated, I had 54% battery life, shut down the phone to clear cache, went to 0%, had to plug the charger to the phone. Hoped this update fixed the battery drain issue. Anyone else encountered battery issues with this update?
I always have mine plugged in when updating. It didn't take very long for mine to update. My Note 4 is definitely running faster and smoother than it was before. I always wipe the cache partition after an update. I've never had to do a factory reset. Maybe it's because I haven't downloaded a lot of applications. I really can't say.
Posted via the Android Central App on my Samsung Galaxy Note 4
Mine is taking forever as well. Hopefully, it doesn't fail when it's done.
Mine is failing too. And it takes forever to download each time.
Sent from my SM-N920T using Tapatalk
I was getting ready for bed when I saw the update. I plugged it I and just let it go.
I us due with FB anymore and the camera lag is MUCH improved.
The update keeps failing after it finishes downloading.. =/
Mine does the same thing. It downloads he 600MB+ file, then it reboots, seems to enter the software download system but then reboots again before installing. I get a message that the update failed.
Been through this twice in the early AM of 10-10. Even downloaded Smart Switch on my Windows 7 PC but seems the update hasn't gotten there yet (OC6).
Yep. Plugged in every time. Could be a corrupted download giving a false completion. We will try 1 one more time: plugged in and jumping 5 days on the current day. (DM Server says I have to wait 89 hours).
They're slacking on the changelog but the boyfriend says his icons look clearer.
Last time I checked I don't think att let you update firmware through kies. Never has with any note I've owned.
Or should I say att branded Samsung notes
yeah ive downloaded it twice now both failed. the second time i actualy set my phone on airplane mode just to be sure nothing was interfering with the download. im curently trying again for a third time. hopefuly it works. if not hopefuly someone finds a fix for it.
Well, I tried again. The phone pretty much bumping the router.
Set the date to 10/14 (so the DM allowed checking), downloaded the file, the phone restarted to installation: BOOM! Error at 0%
Darn!
I was hoping the update would have the themes but it doesn't. I don't really see anything different appearance-wise.
Mine did the same thing. I cleared cached data in the Settings, storage menu item and then the update worked
Hey guys, I had to set-up a new account because my old one was messed-up so this is in essence my first post all over again.
Anyway, question. I just last week enabled full disk encryption on my device as well as encryption for the SD card. Will the update to 5.1.1 mess with the encryption/files at all?
If I have to, I guess I can decrypt, update, then re-encrypt however I'd like to not do that if I can help it since it will take forever just to decrypt the SD alone.
Does anyone know the answer to this. I believe it will be OK however, I'm not an expert and would like someone with more knowledge to chime in. Thanks guys.
**EDIT - I'm playing it safe and am decrypting both the device and the SD card since I won't be able to update until tonight when I'm in range of WiFi however, if anyone has any knowledge of the encryption/update process, I'd still love to hear it.**
I wonder how this will work using an AT&T Note on Cricket? Now I'll be wondering if I am just late in the rollout or if it won't update at all without an AT&T sim.
Posted via my Note 4 on Cricket
Mine downloaded the update while i was sleeping and i accepted once i woke up.
Overall the phone feels much faster and snappy like when i first got it, before Kitkat. The only visual change i have noticed thus far is to the notifications menu and border. I was really hoping the battery issue would be addressed but Im not seeing any changes in that regard so far. With moderate usage, I could get my Note 4 to last me two days without charging when I first got the Phone. I will cross my fingers for marshmallow. How is everyone else doing with battery life?
Overall this is a relief, I didn't want to upgrade to the note 5 and loose my expandable memory and changeable battery, but the bugs where starting to drive me nuts. Much happier with my note 4 for now.
If you're expecting different appearance, you're in bad luck. This update only helps us by improving the sluggishness from 5.0.1 and ram management.
cp0629
