- Sep 3, 2017
- 5
- 0
- 0
I recently bought a used note 4 frim ebay. It was listed that it had problems with resetting and freezing. Indeed it turned out the phone reboots frequently, brining me to a"Downloading... do not turn off target device" Along with that there is a debug console message that says mmc_read failure. Nevertheless after about a hundred tries I managed to reflash the thing (Odin kept failing to write the rom). Still the reboots persisted giving the same mmc errors persist. Sometimes the dubug would says mmc_write fail sometimes it would say mmc_read fail, sometimes both. I then ran into some topics sayin that it's definitely an inherent hardware issue that is pervasive on note 4s. The multimedia controller (mmc) chip seems to fail over time on these. Now this mmc chip manages the flash memory as far as I understand, so if it's failing then the whole 32 gb internal flash would soon become inoperable and I won't be able to boot at all. With all of that said I managed to fix the problem completely. I noticed that the phone only reboots when the screen is off, so I assumed it had something to do with the standby state that the cpu falls into after idling for a while. I simply aquire and hold a partial wakelock on the cpu (there's an app for that) and the phone works flawlessly, never once has it rebooted during this past week and I use the phone heavily everyday. The battery drains a little faster but that's a nonissue.
Now that's all well and good however I do have some future concerns as to the failing chip. First of all I don't entire understand why the phone works so well even the the memory controller has trouble reading/writing. I save files all the time, download apps, transfer files from pc and never had an error saying that the file can't be written or read nor had I ever had an app crash. So I'm a little confused why that is.
The second thing is that I'm still not sure I mitigated the issue completely. Will it eventually get worse? Will the phone stor age still degrade over time? If so how long approximately can the phone last in working order with such a condion. Thanks.
