Galaxy note 5 soft buzzing sound when using s-pen on screen?
Miss Galaxy
Active member
Jul 4, 2014
41
I've just bought a white galaxy note 5 off ebay for £389 (white, verizon) and I've noticed that when I use the S-pen the screen (or the pen) seems to make a very low/soft, pencil writing/buzzing noise as I am writing? Is this normal or is it a fault?
Edit: just gone through settings and found that it's meant to be like that so I have turned the sound off, whoops! I just don't remember having that on the Note 4 so I wanted to make sure
"Meant to be like that" means something loose inside the pen or inside the screen. (The S-Pen isn't just a plastic replacement for your finger, it's a ;oy og electronics.) Some buzz, some don't. (Cheaper, buzzes, think about it.)
I have turned the sound settings off for the s pen and it's stopped completely. It was more like a scribble sound, but thanks for your reply.
Jackwills2567
