Galaxy Note 9's "Lift to Wake" Feature Not Working!
Are you in any type of power saving mode that maybe disable it?
If not already, try and put it in performance mode
It was in OPTIMIZED mode. I selected PERFORMANCE mode and did the search again.
No joy.
You went in settings then advanced settings scroll down to motion/gestures?
Restated while still in HIGH PERFORMANCE MODE.
Went to SETTINGS > Advanced FEATURES and see no MOTION & GESTURES.
Here is the whole sub menu...
Lol thought your on pie
AHA! So this IS a pie feature!
Boy, did I waste a ton of thread space for no reason!
No, I'm in the "I'll stay on Oreo until the Rapture group". I used AdHell 3.1 to disable both SYSTEM UPDATE apps on mine and the wife's Verizon Note 9s. Hopefully, that works at holding off the pie.
It's all good
You dont want a slice of the pie lol
I usually leave AOD on , just don't like lift to wake as I'm walking holding phone it wakes up the screen I end up hitting buttons or if I have it on passenger car seat from vibration it wakes the screen also
But Oreo is last years cookie! Pie all the way for me.
I am glad you figured it out.
drayb
