Galaxy S3: battery saving setup
saab61
10
hey guys
i have an unrooted samsung galaxy s3 android 4.3
i have just hard reseted my phone and did a factory reset
i am looking for a setup to save the most battery possible.
i dont care if i have no connection and recieve no messages. i just want to save as much battery possible no matter wh
do you guys know any tips, tricks, setups, settings or battery saving apps that really works?
tell me what you guys are doing to save the most battery possible or wich settings and apps you are using!
tank you very much!
Re: battery saving setup
If you really don't care about being, essentially, offline, you can turn off wifi and mobile data. You might also check out the Greenify app in the play store. I think it's the one battery saving app that does more good than harm, if you configure it right.
The biggest limitation is that on a non-rooted phone Greenify won't put apps to "sleep" automatically when you turn the screen off. Instead, you need to put a widget on your home screen and tap it to put all the apps you've specified to "sleep." A little bit of an annoyance, but it probably becomes habit pretty quickly.
Ashok Dharshan
