Galaxy S3: Extended Battery?
Re: Extended Battery ?
I have the 4500 MAH extended life.I got it from Gorilla Gadget! Ran it through 4 cycles. Last about 3 days. I'm on my phone lots with my work and all!
I have the Hyperion 4500 Mwh and found about the same performance. I love it and strongly recommend it. I think it was 30 or 35 on amazon.
Are there any cases available from any company that makes the batteries? I know you get a replacement back door to fit over the battery but what about phone protection like a case on top of that?
Sent from my VZW Samsung Galaxy S3
Got the hyperion 4200mah seems to blast me a full day with heavy usage.
Sent via Tapatalk
For about 25.00 you can get the Gorilla Gadgets battery with nfc chip and back cover . Beats the heck out of over priced Mugen batteries, and is better than cheaper ones with no nfc chips for sure !
=rxgadget;2540132]Are there any cases available from any company that makes the batteries? I know you get a replacement back door to fit over the battery but what about phone protection like a case on top of that?
I bought the 4400 Anker that came with a cover and bought the Hyperion 4200 case. It's a real tight fit, but it will fit.
I'm using the hyperion 4200, have been for the past 3 weeks or so. On average user battery last a good 2-21/2 days.
Lemon makes a 7700 mah s3 battery for every carrier and it comes with a case. Its pretty bulky and makes it kind of heavy but the battery lasts along time (although it takes a long time to charge).
Sent from my SPH-L710 using Tapatalk 2
I have the ZeroLemon 7000 mh battery. All I can say is wow....I got 5 days out of it. I'm on my second charge, and its been going for 3 days and im at 56 %. They tell you to run it to 2% before you charge it. I used to have to charge my stock battery after 8 hours of use. What a great battery. Yes, the size is bigger, but so worth it. Also, you don't have to use this battery all the time,only when you know you need extended power.
I started out with an aftermarket 4400 mah battery and then switched to the OEM 3000 mah. I'm 100% satisfied with it and have never not been able to make it through a day and usually go two days before charging (assuming lighter usage). Diztronic makes a TPU case that fits perfectly and looks much better than the ones that come with the aftermarket brands.
Unless you're somebody that spends a lot of time away from an outlet for days at a time, skip the larger batteries and stick with the OEM. That's my opinion, no offense meant to anybody that likes the larger capacities.
I couldn`t add nothing more, Zerolemon always fulfils expectations:)
I`m waiting for the day it will released at least a 3000mAH battery for S4 mini, although 7000mAH will be perfect
vik
