Galaxy S3 Wifi/battery problems
  • Thread starter Thread starter Unregistered
  • Start date Start date
U
Unregistered
Ive had my Galaxy S3 on T-Mobile for over a year now, and I've never had these problems until a few days ago.
Just a few days ago, my phone's wifi started turning on automatically, but it wouldn't connect unless I manually turned it off and back on. I would put my phone to sleep and pick it back up a few minutes later just to see that the wifi was on, but disconnected.
Also, around the same time, I noticed that when wifi was connected, the download speeds I received were less than 1 mbps, when my internet provider promises 30 mbps. This problem comes and goes, but it usually happens at night. None of my other devices seem to have this problem at all.
Another thing I've noticed is that on my battery charts, Android System and Android OS have appeared as top battery users, and this happened around the same time the WiFi problems showed up. I've downloaded a battery monitor and a wakelock detector, but I cannot seem to find the problem. This problem occured without any updates or new apps downloaded on my phone, so I am very confused. All my WiFi settings are normal, even on the advanced screen. I'm not sure if all these problems are somehow connected, but they all appeared at the same time, although they may be completely unrelated. I would appreciate any help you guys have to offer.
amaka
