Galaxy S3: Wifi disconnecting.
Re: Wifi disconnecting.
My samsung galaxy note 8.0 keeps having wifi problems sometimes is there anything I can do to stop this wifi problem ?
Help! I'm starting to have issue with my wifi disconnecting randomly on my Galaxy S3. In early January I updated my phone to version 4.3 and that's when the disconnecting started. It doesn't make sense to me why this happening. My husband has the same phone and he also did the update, but his phone isn't having this problem. This is so annoying!
I have a Samsung galaxy s 3 made for Verizon. I use it with straight talk service. I have **** wifi connection. I need to access the secret menus to turn off wifi power saver. I've tried ever code I've seen on forums to no avail. Any new suggestions?
These aren't working?
http://forum.xda-developers.com/galaxy-s3/general/samsung-galaxy-s3-codes-secrets-t2098642
Are you on stock or custom ROM? Which stock version or custom ROM is it?
If you're rooted you can use wakelock detector to figure out which wakelocks you need to manage for what you want and then use an app made to manage wakelocks to see if you can control it the way you want.
My wifi keeps disconnecting on my S3. I did the whole *#0011# menu then wifi but there is no green button . Any other advice
I had this problem with my Galaxy Tab A6. It would work fine then just stop being able to connect to my router. I tried everyting, recycle the wifi, reboot, clear the cache. Finally I rebooted the router and it instantly connected... but the problem recurred....
So did some more research and ended up changing the phone to a static address...So that the phone tells the router which IP address it wanted. Changing this setting solved my problem!
byronsss
