Galaxy S4 major battery drain issues.
To fix my KitKat battery issue, I disabled background data. Not only does the battery last, the phone no longer overheats. It's a pain if you need emails in real time but I don't and just check it periodically.
Sent from my "no longer 120° or battery guzzling" Sprint Galaxy Nexus, thanks to help from the AC forum
Hi. Since kit kat upgrade the battery life is totally reduced. 1% per hour without use and 20% per hour with internet or phone use. All backgrounds reduced. Use of the excellent gsam application. Any idea before switch to next iPhone?
I would charge my battery overnight to 100%. 4 hours later the battery would be at 10%. This has only happened in the last 2 weeks. My phone would also be red hot after charging After reading other forums I have done the following
1. Turned off motions and gestures and Air View from the Settings. I didnt really use these anyway
2. Turned of Use GPS Satellite from the Location in Settings
3. Clicked Power Saving Mode from the drag down menu
4. Disabled sync in the Settings - Accounts for all the accounts
5. Downloaded Battery Booster Lite
6. Deleted the last 3-4 apps I downloaded - could have been a rogue app
7. Turned off Wi-Fi when I was not in a Wi-Fi area.
8. Deleted cleaner apps. Manually deleted cache etc from the Settings-More-Applications Manager
Nothing worked. I still had the same problems as before up until yesterday. I read on another forum that the sd card drains the battery on the S4. I took out my sd card. Simple as that. It worked. I have taken my phone off charge 3 1/2 hours ago. Battery is at 80%. Would have been down to 30% or less when I had the issues.
Nazeer zaheen
