Galaxy S4: Problem in 4.4.2 update with email
Same here I also have mini S4! data sync already checked...nothing going on with email. Downloaded K9..that does work after fiddling about with it
Google "Samsung S4 Sync Turned Off Fix YouTube" and you will see my video solution for this problem. I hope this helps someone fix this problem. Thanks
Worked perfectly! Thank you. Head was getting sore from banging against the wall. I thank you and my wall thanks you.
Re: Problem in 4.4.2 update with email
Hope it sorts you out.
Solution for Email sync disabled.
here is a simple solution for 4.4.2 sync problem.
go to > settings >connections tab , then 'Data Usage' , then click on hard menu button (bottom left) of phone-check (tick) Auto Sync data.... hope it helps
best regards
john.
Thanks alot bro.. my sync is on again
best regards
john.
.....created an account just to let you know this post saved my life (y). Thanks
Thank you John. My email works great now. I believe it was an issue with the installed Android email on my Samsung Galaxy S4. Installed the Aqua mail.... Thank you for taking the time and effort to help "us". Michael
lumaplay
