Galaxy S4: Watchon Notification Icon won't go away!
Hi all I had this problem on my samsung s4. I figured out how to get rid of this annoying app watchon.
Go to settings, the select the more tab at the top the select application manager the select watchon. THEN SELECT uninstall updates when you Confirm it will ask you to set back to factory default select yes and this will get rid of it on all occasions and any previous settings will be erased for this app.
To turn it off you need to go to application manager and search ALL. Once you get to Watch on open it and force stop. Don't use the Running Section use the All Section
This is actually an app called, Peel Smart Remote. To remove, perform the following.
1. Settings
2. Application manager
3. locate "Peel Smart Remote"
4. Select, "Disable"
Select any prompts to remove data or uninstall all updates.
richardgroover
