Galaxy S5: How's everyone's battery life so far?
does vzw s5 have all the major battery problems that the vzw s3 does. I am reluctant to get to get the s5 if it will have all of the major problems that the s3 has after software update.
Absolutely not!
VZW here on the S5.
I have very good battery life.
Depending on how I use it on any given day, the battery percentages vary from 85% left down to 35% left.
In extreme cases where I am not using the phone, it will go several days between charges. But on this situation, I have DATA and WIFI, Sync, bluetooth all turned OFF. That prevents any apps from trying to connect to the internet.
If I leave DATA on all day, it typically shows 50%+ to maybe 70% battery left. Depends on how much I use the phone.
One big caveat... Uninstall all of the Amazon named apps that came with the VZW phone setup. Some of them can only be Disabled, but if you don't the battery life will suffer badly.
Needless to say, I have Disabled ALL of the VZW bloatware.
I have turned off the following on a Verizon phone:
Accessories, Amazon, Amazon App suite, Amazon Kindle, Amazon MP3, Appstore, Audible, BlurbCheckout, Bubbles, FamilyBase Companion, Flipboard, Message+, Messages, MyMagazine, NFL Mobile, Picasa Uploader, S Health, Smart Remote, Travel Wallpaper, Verizon Support & Protection (McAfee), VZ Navigator (pay for fee Navigation.... Google maps is free)
Google branded that I turned
OFF:
Contacts Sync, Play Games, Play Movies & TV, Play Music, Play Newstand, Hangouts, Isis Mobile Wallet
Re: How's everyone's battery life so far?
Nope. I never use battery saving modes.
Then how is your phone idling that well? Unless you have absolutely no apps syncing in the background or are in airplane mode during the night, I don't see how your phone can get such tremendous idle time.
Share your ways!
Sent from my SM-G900W8 using Tapatalk
Share your ways!
yep. i turned unwanted things off thats it, no secrets im not on airplane mode
Normally my phone is off the charger at 7:30am and lasts til 10pm-1am. Today it was off at 9:30am and it's at 50% as of 12:45am, first night that I'm not even going to charge the phone. I'm sure it will be charging during the work day tomorrow. I'll post screenshot before I charge it up.
Share your ways!
Probably because he hasn't actually used the phone very much at all and spends more time turning things off ;) the screen has only been on for 5hrs in 6 days, that's just over half of what I would do in one day. I could quite easily achieve that uptime without charging and you could also easily smash the uptime by using UPSM, but whats the point, use the phone as its intended, which means the screen should be on for a long time.
As promised, the screen shots are here. I'm finally at 2%, surprised it made it this far
Sent from my Galaxy S5 using Tapatalk
I didn't use UPSM. Just posting up my battery life to compare with others. According to the internet, max screen on time is a little under 8 hours. So I consider my battery life is above average per say.
Here's mine. Wifi only for 2.5 hours.
Almost 3.5 hours of screen on time and 50% battery left. At this rate it may be possible to get 6+ hours of screen on time if I ran it down to 0% or near it if I continued to use the phone the way I did today.
Sent from my SM-G900V using AC Forums mobile app
I never said you did. In your last post you showed screen time of just over 5 hours, now its 8 hours? :) For the record i did 3 days uptime with heavy usage, over 6hrs of screentime PER DAY, using UPSM overnight. I wouldn't say your battery is any better than average to be honest.
I've never gotten 8 hours of screen time, that's only according to the people that test the phone on the internet as I mentioned.
You definitely got better battery life than I do if you are going 6 hours of screen time with heavy usage. I would like to see a screenshot if you don't mind.
I came from the note 3 as well. did you do anything to your s5? your battery looks good
Sent from my SAMSUNG-SM-G870A using Tapatalk
Yea I agree. I have the S5 setup just like the N3 and it's nowhere near the life I get on the N3.
Ok I exaggerated it is similar to yours at best, so about 5hrs
Sent from my SM-G900F using Tapatalk
tryhomematch
