Galaxy S6 edge: Screenshots!
Hi there, I really like your set up. I was wondering, if you would please share your set up? Thanks.
Thanks.I'm glad you like it.
The weather is Zooper widget icons called "Half Weather by Kelly Kretchek. He makes some of the best weather icons out there. Check him out on Google +
The icons are "Black and Cyan" by Stealthychief. Link: https://forums.androidcentral.com/e...on.pack.black.cyan.icons&hl=en&token=sG7bGgxW
The clock is called "FORM Clock Widget". Link: https://forums.androidcentral.com/e...beatonma.formclockwidget&hl=en&token=52RZ6M5h
Wallpaper I found on Google+
Oh yea.......I use Nova Launcher Pro.
Sent from my Galaxy S6 Edge via the Uncarrier
Hi - is that a standard weather app or is it part of a different launcher? Been searching for something like this!
Mine for this week..... or until something better arrives! Special thanks to JoeR32 for pointing out the weather widget I've been searching for!
Clock widget
Transparent Clock & Weather widget
Custom icons from Zedge
Solo launcher
Whicons
Chic theme
Custom created wallpaper dock
Amber weather widget
Posted on my Galaxy S6 edge🔪(S is for Super) via the Android Central App
My setups from the past week or so ...
And yesterday ...
Very interesting post. really informative. of all the blogs I have read on the same topic, this one is actually enlightening. :) :)
Just got my phone yesterday. Using Nova and icons from. Zedge icons for something different.
Today's setup
Purple
BennyHuyghe
