Galaxy S7 Edge Android System using 75!! How can I fix this?
  • Start date Start date
A
AC Question
Galaxy S7 Edge Android System using 75%!!
I've been noticing that for the past few days, my battery has been draining WAY too fast. After 2 min off the charger, it's at 98% and just goes downhill from there. In the settings->battery, the Android System is using 75%!! It was at 12% or so ever since I got it and is now draining my battery. How can I fix this?
Re: Galaxy S7 Edge Android System using 75%!!
Try first a Power Off and Restart.
Tell us what that does.
I tried and the 75% held. Android System 75%, Android OS 6%, Screen 6%, Cell Standby 2%.
Yes, but I mean, does it make a difference after say a day's use? If, after charging to 100%, you still see high Android OS battery usage after a day's use, it will not have made a difference, and other tactics will have to be considered. But it's always worth trying the simplest fixes first.
Also, welcome as a new member. :)
Thank you :) No, it's no better after the day. I've checked the battery usage regularly every few hours and it's been between 50%-75%, even with all of the apps closed. I didn't think much about it up until 2 days ago. I was finding that just having it with me, it would drain from 100% to 65% in the course of an hour or two.
probang
