Galaxy S7 Edge - What screen protector ?
I to like the Armor Suit but....when I put my case on several of the edges at the top and bottom of the screen came up. Sides are fine. Have you had a problem like that with any case you use? If not, what are you using for a case? My case is a Spigen with the kick-stand
Skinomi makes a screen friendly protector. It's an exact fit for using a case. I would say there's less than 1 mm separation from the edge of the Skinomi to the edge of the Spigen Tough Armor.
You can pick up a 2 pack for $8 on amazon.
Cheezy313Bby
