Galaxy Z Fold 2 Edge Panel with Case
DrNitun
13
Hello,
I have the Galaxy Z Fold 2. Getting a case which enables me to easily access my Edge Panels is impossible. With so much customization available for Android phones, is there a setting (or 3rd party app) which will make the Edge Panel wider (not longer vertically) horizontally? If there is, then accessing the Edge Panel would be not an issue. I know there are many of us with this new phone facing the same issue when we put on a case.
Thanks,
Going to follow, have the same issue, also have issue using the FPS with a case on. I'm currently just using a Dbrand skin.
I was just using the back part of the case to avoid the edge and FPS issue using a case.
Donm527,
Does this case let you access the Edge Panel with ease? Or is it a struggle?
Thanks,
I've just added folders for my outside launcher in place of the edge panel apps ...no case with front edge allows me access to left side edge panel ..
I did pre-order that Latercase but not shipping till December at earliest ...
Donm527,
Thanks,
No problems with the Edge Panel and if they cut the same with Fold 2 you shouldn’t have problem either. Just due to the design as you can see it does not cover any of the screen cut perfectly at the edges. It’s basically a skin make of Kevlar instead of 3M it’s so thin. My problem was that it offered no space to provide a little barrier for accidental touches.
Hello,
Is that a Fold 2 or a Galaxy Note?
Note 20 Ultra. Too bad LaterCase doesn't have more pics of the Fold 2 case opened but being a Kevlar case, pretty sure it will be cut just as tight to the bezel as this one.
Hello,
Had anyone been able to find a good case? I am using the Ringke case. Spigen's Thin Hybrid case is awesome BUT does not fit a Samsung OEM car charger!
What about accidental drops?
pupso4ev
