Galaxy Z Fold 2...
Any adapter to charge and use phone at the same time with headphones? Thanks i know I can use wireless but I like wired better some times.
Is anyone's bud live volume really low??
Try adjusting the position of the buds. I have found that they are really picky about how they are positioned in the ear, when mine seems low just adjusting the buds fixes it.
My number one complaint with them, you have the feature they don't seal up in your ear, but you always have to adjust them since they aren't sealed up and stay in place.
Whats the best screen protector for my fold.2,? One that covers.the main.screen and front. I can't find glass screen protectors.so im.assuming they won't make.any or haven't yet. Thanks
I think both screens, inside and out come with screen protectors already on them.
Elly
Outside screen you can use glass ...though some cases not fitting with WhiteDome...inside screen similar protection can’t use glass obviously but you might as well keep original or go without one on inside ...
Ringke case came in ..I like the feel better than Spigen Thin Fit ..charging port is not obstructed...frame feels sturdier and is a bit more squared off ..
I bought the only case I could find. It's from CaseMate. It's folio style and has a clear cover over the front screen that you can touch through. The sides are all protected too. It's all black. Soft feel. I ended up really liking it.
Elly
Pickle240
