Gear S Notification Extender
Just returned my S2 to best buy today. All you have to do is install Android Wear... don't have to open it or anything, just install it. You'll get all your reply options... same goes for the original gear s. I bought this app... but now that I figured out that AW trick I wish I hadn't.
I installed AW when my S1 was new and it didn't work. They must have made it workable in the Gear update back in the spring.
Good stuff. Glad you posted that.
Support Our Troops !!!
Beast Mode 4
It isn't working for me either. I don't see it in the play store when I search for the app
I searched as well, because the link did not work for me either. I could not find the app. I searched the samsung and the google play store. I DID find one by Bilbo Soft called notifications for Gear S, I'll try that.
Im facing issue problem with bilbo soft notification for gear s..the notification seams keep on sending the same notification info in loop...
I don't know....I installed about 10 minutes ago and seems to work ok so far.
For example..if u have 4 notification unread yet..once the 5th notification come in, it will sending again the rest 4 notification that u have not read it before..so notification become 9 notification with 8 of it is the same notification..
If you have a Gear S and the notifications are NOT WORKING and all settings for notifications are on, download and install INSTANT SETTINGS App on your Gear S from Gear Manager.
This will show that BLOCKING is enabled on your phone from your Gear S for some reason (most likely the speed-up utilities you've downloaded enabled it) and DISABLE it from your Gear S.
Notifications will work again as it did for me.
Please, can you tell me how to get the full version?? Mine is just expired and i don't want to come back to default notifications... In the play Store there is no entry about this app.
Please help me....
Please help me....
Some of us facing the same issue..some can find the app in google play..some cant find it..OP need to investigate why such thing happens..this is paid app..not free app..we pay to the developer..we want to give u money developer..u dont want money??
What trick?
I sent several messages to the developer in forums and in email and never received a reply... Maybe he/them don't want more money....☺
Install Android Wear app on your phone. You don't need this Notification Extender app. I'm not seeing the need for it at all. Maybe that's why OP pulled it.
Maybe you don't know well what this app can do, but shortly makes notifications more readable and more easy to reply from the watch. And more puts the images of the sender in background ...
Loki Samhain
