Gear S3 Frontier - Amazon Straps
Is there a way to remove the folding clasps where it says stainless steele? Is it easy to put on and take off? I thought about getting this band but I have a disability called Cerebral Palsy and I have a hard time putting watches on and taking them off so I thought that this band wouldn't be the right one for me. I bought a milanese loop black band because I thought it would be easy for me to put on and take off. I'm left handed and it's hard to put watches on my left wrist with my left hand. If anyone knows of any bands that would be easy for me please let me know.
You can remove the clasps but then I'm not sure how you would keep it on your wrists. I'm not sure how easy it would be for you but it's definitely easier to put on and take off vs the single side folding clasp that you'd need to pull off to unlatch. If pressing two buttons to unlatch the clasps is too difficult then maybe look into those stretch style watch bands like the one from here.
https://www.amazon.com/gp/aw/d/B01E...ag=hawk-future-20&ascsubtag=UUacUvbUpU5579595
https://www.amazon.com/gp/aw/d/B01E...ag=hawk-future-20&ascsubtag=UUacUvbUpU5579617
I like to wear watches on my left wrist and I have a hard time putting watches on on my left wrist with my left hand. I'm just looking for something that would be easy for me to put the watch on on my left wrist with my left hand. By the way....I checked out the band at the link you provided and where it says compatible watches I don't see the Gear S3 Frontier. Is this band not compatible with the Gear S3 Frontier?
Yes it will. Search youtube for gear 3 videos with straps and you'll find one or two videos showing this clasp. Gotta remember, the straps are the standard 22mm size. You can use ANY 22mm band now.
Yeah I know the bands are the standard 22mm size. I just wanted to make sure that this band: https://www.amazon.com/20-24mm-Hadl...pU5579949#technicalSpecifications_feature_div works with the Gear S3 Frontier before I buy it. If you click on the link and see compatible watches the Gear S3 Frontier isn't included. I didn't want to buy a band that doesn't work with the Gear S3 Frontier.
Yeah, I agree with you. I don't know if it is compatible or not. But I do know the one I referenced is, and it's half the cost of the one you're referencing. :)
It should be. I think the band you're referencing will be too hard for me to use. I don't think I have the strength in my fingers to be able to do the clasp. I think the band I'm referencing will be easy for me to use because I can just put it on and take it off without having to use a clasp.
WatchGecko.
I bought the Vetoo replacement band from Amazon and it didn't fit! The pins that came with the band are about 1mm too short. Poor QC on the manufacturer, but I guess I should have expected that for $8 on an Amazon Daily Deal. Returning.
I wanted a metal band but couldn't find one locally so I ordered this one from Amazon:
https://www.amazon.com/gp/product/B...ns. [ATTACH=CONFIG]247040._xfImport[/ATTACH]
makjojo
