Get a Note 4 or Note 5?
Hey, how'd you get the skin on? That looks so cool. Is that a case or what? Makes the phone look really sharp!
Doesn't it look cool, thanks. It's a skin, pretty easy to put on, and thin enough to put a clear case if you want to, although you need to be extra careful to make it fit with a case. I go caseless anyway, so no issue for me. FYI, it's not recommended that you use a tempered glass with the skin. I think tempered glass is a waste anyway. I have had no screen protector now for several months, no scratches, but I make sure not to put my phone in the same pocket with my keys.
Below are the links to 2 different sellers:
https://dbrand.com/shop?utm_mnsid=UUacUvbUpU4726002
https://forums.androidcentral.com/e...ps.com%2Fdevices%2Fphones.html&token=L0vqmhSS
Jake2H
