Get off my CASE!!
I always get first the ArmadilloTek (now CaseBorne) for my phones; one clear, one tough.
But I only found one case from them for the GS25 Ultra in Amazon this time...
I also get a couple others, just in case, but we'll see how it goes this time around...
Sent From the TARDIS
I was wondering about Karl and CaseBorne.
just to let you know after all twist and turns being afraid i decided not to do speign again due to tough armor current phone has a long stratch on it and smudges back of case due to fall few times in past i and it tough armor ai seems they are same?
i went with and it saying can used a temp glass i went back and forth and got i hope i did right decision getting weds after using 10 amazon gift card
Besides Quad lock does anyone have any case and mount suggestions for Harley handlebars?
Yesterday my nephew came to visit and took out the iPhone 16 that he has, and I liked the case he uses... I thought it was bulky because of how it looked but no, and the material feels spectacular to the touch, the bad thing was the price... the Two that I already have cost less than $20 on Amazon and I quite like it 'Ringke and a Goshteck'.. the case my nephew has is a tech21 EvoArmor $49
Reactions: Laura Knotek
I ended up getting the Pikata and Latercase, both have great fits to the phone and great minimalistic feel if you're looking for that.
They look very nice, but I have two questions... do they protect the front screen well? Do they not protect the buttons on the sides?
Both cases have a lip on the sides so if you place your phone face the screen wouldn't touch the surface. On both of the cases the buttons are exposed and not covered. These are minimalistic cases and don't have a ton of protection that other cases may provide however they don't add any bulk.
I did use the Pitaka case on my S24 Ultra and did have 3 drops each approximately 4 feet and the phone survived all 3 without a scratch, the case did get scratched on the corners where it hit. Each fall was on my driveway getting out of my truck. Hope this helps.
when i open up case that i got poetic guardian magpro case i saw in a little package separated the screen protector well not going to put that on hopefully speign temp glass will hold up better in long run prob will hang on screen protector not sure the screen protector comes with phone seems flimsy
so the magnet that on back of case you just mount it to car?
i have seen this video
if i went to ultra and wanted to do spen thing i would had gotten Poetic Neon MagPro Case<-seems that didn't come with screen protector oh well
ok so website saying Fully compatible with Fingerprint ID with this case. MAKE SURE REMOVE ANY AIR BUBBLES BETWEEN FINGERPRINT SCANNER AND FINGERPRINT STAMP. Please carefully read FINGERPRINT STAMP TIPS on the DESCRIPTION SECTION and watch INSTALLATION GUIDE VIDEO, follow steps for smooth installation. so i guess just don't put that on
what it looks like
For people who don't like to use built in screen protectors, Poetic has included an extra front frame to use with your own tempered glass.<-that temp glass thing
do you guys think i shouldn't had bought temp glass thing and just used the build in screen protector instead or what wonder if i made a mistake then again maybe good thing put that temp glass on it the fingerprint scanner thing might stop working over time if i were use screen protector i don't know
email i got Yes, the Spigen GlasTR EZ Fit Tempered Glass Screen Protector should work with the Poetic Guardian MagPro Case for the Galaxy S25+ (6.7"), but you may need to remove the built-in screen protector that comes with the case.
Poetic Guardian cases typically include a built-in plastic screen protector, which can sometimes cause fitment issues or touch sensitivity problems when used alongside a tempered glass protector. If you prefer the Spigen tempered glass, it's best to remove the built-in protector from the Poetic case before installation.
so i guess when i go over at and t tonight before closed at 7 or have to wait tomorrow i asked them what best to do if don't think spigen temp glass will work i guess return it and just used the plastic built in screen protector i don't know
I personally like the cases that don't have that big camera cut out. I like the look of the cases like Samsung official cases, Spigen cases etc where they have separate vertical cutouts instead of the big cutout which looks bad IMO.
Reactions: kide#WN
I usually go with the Ringke Onyx but saw that they had a Rugged case that wasn't available the last time I needed a case, so I thought I'd try something new. Really liking it so far and I'm sure it'll do a good job if I ever drop my phone.
Got this one. Must have belt holster.
Does that case with regular wireless chargers or only the Magsafe chargers? I would love that but I like using the regular wireless chargers.
Adekanmbi
