Gingerbreaked Stock VD
How is the V9 recovery image differnent than the VD? Does the radio update also update the recovery files?
maybe this is a dumb question, but i'm still kinda new the the rooting and whatnot. i just have to flash this and i have a stock rooted phone on VD?
so i have to unzip it and flash it for it to work (sorry if its s dumb question lol)
You unzip this to the root of your SD card - leave directories intact!
It will go into a directory called - \sdcard\nandroid\mem=477M
You use one of the custom recovery kernels to restore the nandroid backup.
Reboot - and you have a rooted, stock VD Optimus S
i keep on getting a unable to install error. i unzipped and then moved the backup file into the folder with all of the other backups i have. is that the issue?
You do not INSTALL this
You do a nandroid restore and choose the file.
To make it simpler, the directory you saved it - rename it
Instead of naming it BCDS-something
I renamed mine to BCDS-Stock-VD and leave it on my SDCard
The rename makes it stand out when doing the nandroid restore
That way I can always restore to stock for testing and also updating PRL and Profile
then I flash back to my current nandroid backup.
HELP :-)
The link doesn't work-- "Invalid or Deleted File"
I'm not able to complete my phone activation. Does anyone have a copy of this file?
OR a pointer to another source for a ROM that will allow me to activate an Optimus S on Ting?
thanks
You will need to flash the stock rom. If you need it, just ask.
Previous Username: UnrootedDroidOwner
Current Phone: Lg MACH(LS860)
Old phone: Lg Optimus S(LS670) Currently my MC:PE server hoster:)
And soon to come is a Nexus 7 2012:)
Hey Clutch,
Can you send me a link to the stock rom for the Optimus S as well?
I have found 3 dead links to this restore and I need it in order to activate
Thanks
cenedo3697
