gmail problems
the lawgiver
5
today i am not getting notifications
new email doesn't appear in the app inbox
in app can't archive or change labels
i'm having the same problem. :/
did you just update the OS? I think mine started to happen after i did the update.
I received my update this morning, but I haven't experienced any problems with Gmail, nor the Motorola email client. Perhaps try removing the account and adding it back.
updated last night, havn't received **** since yesterday even before i updated. yahoo or gmail. actually some yahoo, but absolutely no gmail
I updated and haven't noticed an issue. However, i did have an issue with it not syncing emails before the update. Somehow it had deselected auto sync. So def check that for the sync issues.
also check your battery saver as well. if you have a data timeout set, you wont get emails pushed to you when the network shuts off
hmm - I was under the impression that even during a data timeout, push gmail would automatically rewaken the data connection? is that wrong?
Also just to clarify: Smart Mode gives you the option to set data timeouts for peak and non-peak hrs, does Battery Saver mode automatically put the phone in data timeout if there's no activity for 15 mins?
i was under that impression as well, but i can tell you through my experience the past couple of days that a gmail push does not "wake up" the phone.
and i meant battery manager, not battery saver. but for the record, battery saver puts it to sleep after 30 mins, no peak hour setting. it also lowers your brightness, whereas smart mode uses auto brightness, which i love
so i made sure my battery manager didn't specify the peak hours and I turned on push (it was unchecked after i did the update) but it still doesn't push my gmail. I have to manually go in and refresh it.
I've cleared the data and cache of both the gmail applications and i've removed one of my two gmail accounts, put it back on, and it still hasn't been pushing. :/
Im having Gmail issues too...Universal Inbox and push notifications not working. However when I go into the gmail app and manually refresh, then all of a sudden I receive all my new emails at once. The fact that others are reporting same leads me to believe this may be a Gmail issue and not a phone issue?
Md ripon sorkar
