Javier P
Ambassador
- Feb 21, 2014
- 19,478
- 6
- 0
So you don't know what you are doing and instead of learning how to do it you decide to trash an app that does allow you to do exactly what it says it does. If you had asked instead of throwing a fit and falsely slandering the devs, I would have been happy to tell you how, but I think I'll pass.
A bit harsh but about right.
Two different things. I don't know any way to IMPORT your drawer folders from TW to Nova. And you don't add apps into a drawer tab/folder just dragging them.
Said that. You can create tabs and folders in your drawer with Nova Prime. The process is this simple.
Go to nova settings - drawer - drawer groups. Once there select tab, folder, widgets ... Press + to create one and the pencil to add/change the apps included. You can choose to keep the apps in the main tab as well or not. Just check the box besides each app to include it.
Done. Nice and easy. Ask if you need any help.
