Good Car mount for a note 5 with an otterbox defender
Link169
19
looking for a good stable car mount that won't tilt or randomly fall off. Yes it is in an otterbox and i do not remove frequently. Thanks!
Ibolt,, been using for 3 years now.
The TYLT Vu wireless is a great one. I have the Neon Green one brand new in the box that I would sell for $50.00 plus a little for shipping.
iOttie Easy One Touch 2 Car Mount Holder for iPhone 6(4.7) Plus(5.5) 5s 5c, Samsung Galaxy S6 Edge Plus S5 S4, Note 5 4 3, Google Nexus 5 4, LG G4-Retail Pack https://www.amazon.com/dp/B00JRGOKQ...ag=hawk-future-20&ascsubtag=UUacUvbUpU4657934
Want to upgrade to the one with qi charging. Fits fine with my Pelican Voyager case
Sent from my Note 5
I use iOttie too. It is great and replaced my iBolt after it wore out.
Sent from my SAMSUNG-SM-N920A using Tapatalk
So you're using the OtterBox Defender case with the Note 5 and it fits into the iottie easy one touch 2 car mount? Cause the specs for the case is 3.2in and the car mount can hold devices up to 3.2in, so it must be a tight fit. Can someone please confirm if it's a tight fit and is it hard to fit the phone into the car mount, or does it fit ok with no dramas?
So I just looked at the dimensions and the one touch 2 car mount can hold device up to 3.2 inches and the defender case is 3.2 inches, so either it's going to be a tight fit but still fit ok or a tight fit but too tight for it to fit ok. Hmmm... To buy and take the risk or not to buy
I have a iottie one touch 2 and it worked great with the note 4 and a case. Now, with my note 5 and an otterbox commuter not so much. Phone pops out now and then due to the rounded back of the note 5. Maybe with no case it would fit better but no case is not an option for me in my line work.
Any chance you found a good one yet? I just started looking and dont want to waste money on ANOTHER one that wont fit this phone with the otterbox :(
I've been using this https://www.amazon.ca/gp/product/B0...hawk-future-ca-20&ascsubtag=UUacUvbUpU5114952 on all cases on my Note 5. I recently bought a Love Mei Metal case which is fricking huge and heavy. With this mount open as wide as it goes I was just able to wedge the Love Mei in and it held fine and staying in place. I'm pretty sure the Otterbox Defender isn't as wide as the Love Mei and I know it definitely isn't as heavy. I just got the UAG and it fits in this with plenty of room to spare. For the price this mount works amazingly well, even better than some of the higher priced mounts I have tried.
dumpsterrentals76
