google 7 wifi connection problem
  • Start date Start date
A
AC Question
I am trying to help my sister connect to wifi under my guest network. This has worked until recently. When she turns on wifi, the screen says on but when we try to go on youtube for example it will say there is no network connection. I pressed the network name to connect but it does not do so automatically anymore. It is asking for a password but I honestly don't remember it. Is it possible to change the password and how would I go about it?
Welcome to Android Central! So you're saying that your wifi guest network requires a password? Is this your own wifi network, or is it a network provided by some place like a condo complex? If it's your own wifi network, then try logging into the router to change the settings (see the router's manual to learn how). You might have to do a factory reset of the router to get rid of the password requirement.
