Google Nexus 5 is stuck on google start page
You don't have to do a factory reset...Press and hold power and volume down for 10 seconds.Then.. If you know how to load a custom recovery tool like TWRP load it and wipe the cache.. If you don't know then try wugfresh nexus root toolkit and then in the advanced tools select custom recovery. The phone will boot into twrp and then you can wipe the cache, reboot the system and it'll surely boot to your android :) I hope that was helpful
Ok so pardon me if this has already been answered and gone over, I have been up all night (LITERALLY) trying to search for info but can't seem to get anywhere and its really beginning to frustrate me. I just got the Google Nexus 5, and was trying to root it, and I did succeed in rooting it however after I downloaded chainfire 3D and went to install cfw and it rebooted, it stopped on the Google startup and froze up. I've tried locking and unlocking it as well as wiping the data and the cache followed by a reboot. It still wont start or go further than the Google start page.
Oh and I've tried even waiting for several mins AND NOTHING.....
PLEEEEAAASSEEEE HELLLLLLP lol
PROBLEM IS FIXED!!!!!!
This is how I solved my problem.
Step one- Install adb and fastboot drivers forum.xda-developers.com/show....php?t=2588979
Step two- Download the latest factory images from here. developers.google.com/androi...ges#hammerhead
Step three- Extract the factory images you downloaded (Use WinRAR). www.rarlab.com/download.html
Step four- Unlock your bootloader
Step five- Power off your phone.
Step six- Boot it in fastboot by pressing and holding Power Button + Volume Down at the same time.
Step seven- Connect your phone to your PC through your USB cable.
Step eight- Execute the flash-all.bat script (for Windows) or flash-all.sh(for MAC and LINUX) in the folder where you extracted the factory images.
Step nine- After everything finished, select "Recovery" using the volume buttons.
Step ten- When a small Android appears, press Power Button + Volume UP.
Step eleven- Select "Wipe data/factory data reset"
YAY!!! Now Reboot. Your phone should be stock
How do you suggest I unlock the bootloader when my phone is not even booting up? I cannot enable USB debugging or OEM unlock. Any way to do it simply using fastboot or something?
TheGreatApe00
